Hey ya'll. Just wanted to let ya'll check out my plans for lifting the jimmy and give up any comments/advice that may be helpful.
It is an 89 jimmy and I want a total of about 6 inches give or take a little.
For the front I want to do 52" spring swap with some 2" lift springs. But on the 52" swap I plan on moving the front spring hanger directly underneath the body mount. I've read that some people on here have done that and it allows the axle to stay in the same location. That'll keep me from needing a zero rate, hopefully.
For the rear I plan to put on a 4" shackle flip and 2" springs again.
Now for tires I am having trouble deciding. I want to run the 37x13 boggers, but I know 1/2 axle won't handle them for long. Eventually I want to do a d60/14b swap. So i've been throwing around ideas. Should I just go with some 35's for now until I'm ready for the 1 tons, should I just go ahead and put the 37's on and "drive carefully" lol, or should I try to be patient and do everything at once? Would 10 bolts hold up to 36's ok?
There are no rocks here in MS, just mud. And the amount of wheeling I get to do is not much. Kinda the reason I don't want to do the d60 right now, because I think it might be overkill for my needs at this point.
Anyway, let me know what ya'll think. thanks
