Lift Q's
Elroy303030
Branson, Mo.
I have a 4" lift right now, all Springs. I would like 6". My question is what would be the easiest way to get 2 extra inches of lift? Could I do a add a leaf with a zero rate? Or would putting a body lift be the better way to go? And if I add 2" of lift would I have to get long drive shafts and drop pitman?
Add a leafs would make it ride stiffer. Body lifts aren't that hard to put in. 2 in. block in the back and an add a leaf in the front and you might not have to lengthen rear shaft.
Tarey
