Not sure if ORD actively monitors here? Anyway, 10+ years ago I got some custom ORD springs, going for 4" lift or so. I think I gave some bad info, maybe related to my having 1-ton axles, and it came out more like 6" (see pic). It's always bugged me, but I lived with it and even got the crossover kit to fully enable the articulation these springs allow. But at this point I'm never going to do crazy off-roading with this truck and I'm thinking about how to tame it. I'd like to get it down to that 4" type range for a more subtle look, and to have it be a little more streetable.
For starters, is there some particular measurements I can make to see where I really stand in terms of how much lift I have? From there, am I likely to find an off-the-shelf spring set given that I have D60 and 14BFF ... I mean where it would sit level? I don't need to do serious crawling, but how much ride would I sacrifice going to off-the-shelf (if that's possible)?
In case it helps ORD, here's the spring specs:
