lift spring question
rgretzinger
Longvew, TX
OK so I currently have a 4 inch lift with pro comp springs. Ride sucks really bad. I am buying new TC springs all the way around. Do I need 52" or 56" springs in rear? I know it came with stock 52 inch springs but that was at stock height.
all K5's come with 52 rears, whether stock or a lift spring...
one reason your ride is crappy is due to lift springs in the back.. why not go shackle flip? you can easily install a stock 56 spring in the back at that time... it'll ride like a caddy as opposed to a dump truck...
rear flip kit and 4 or 5 leaf + overload stock replacement leafs. will ride much better than lift springs.
5 leaf + overload i have used in the past with flip kit works good rides good. http://stengelbros.3dcartstores.com/22-403_p_3163.html
4 leaf + overload smother ride little more rear saggy butt but cost more than 5 leafs. http://stengelbros.3dcartstores.com/22-909_p_2476.html
ord sells tuff country leafs http://www.offroaddesign.com/catalog/TuffCountry.htm
ord flip kit http://www.offroaddesign.com/catalog/shacklekit.htm
diy4x flip kit http://diy4x.com/cart/index.php?route=product/product&path=24&product_id=125
ord and diy4x are vendors here . = you say ck5 you get discount by verifying mebership here.
