lift, steering question
74huggerorange
Registered Member
Tulsa, OK
I currently have a 4" rough country lift on my 74 k10 and am looking to get new front springs. The rear of my truck has procomp springs and sits 1" lower than the front and I am fine with that so I was thinking of getting 3" tuff country EZ ride front springs. I have the raised steering arm on there for 4-6" lift and right now my draglink (stock steering setup) is just about parallel to the ground. Will it be ok with 3" springs on there and this steering arm or will I need a stock steering arm(I hope not I chunked it) with a drop pitman arm?
Thanks guys
i dont see any problem with it, i would just do the 3" springs like u want to and see if there is an issue then. just have the stock arm there if u need to replace it.if u do need to, good news is u already had the stock one off so it will be an easy job replacing it back to the stock one.
