Lift / tire size question
red5033
Newbie
Just bought a 85 K-5. It had no lift and 33x12.50's on it and the tires rubbed when I turned the wheel fully. I just finished installing a 4" suspension lift and it clears the tires with no problems. Now Im considering going to a larger tire but dont want to be back where I started from. Will 35's rub with the 4"? Im not against some minor triming...If the 35's are out, Ive seen some 34's out there..Oh, and Its mostly a daily driver with some occasionaly light duty off road use here in Flat Florida..
Thanks,
Red
you'll need to trim a little, but if you keep the anti-sway bar on there you should be fine with 4"/35s.
j
[ QUOTE ]
j
[/ QUOTE ] You can also add a set of ORD Zero Rates on both the front and back for a extra inch of lift.
