lift
83blazer
Memphis,TN
How much lift should i have to fit 35x14s without rubbing i am willing to hsave a bit but i do not want to cut half my fender up
HOOK IT TO WHAT YA DONT WANT
It really depends on how much articulation you have on the trails. If there isnt much you can get away with 4-5 inches. They with rub a little, but will clearence themsevles out and doesnt look bad. If you have a lot of articulation I would recomend at least 6 inch lift. I run 35x12.50s on a 4 inch lift and articulate alot. It sounded bad the first time they rubbed, but after two times out they quit rubbing, and you couldnt tell they pushed them fender back. I went slow though because I knew they would rub. If you go fast it could cause alot more damage.
86 Jimmy 4"lift 35"MTRs locked front.Other cars 69 Firebird w/525 hp,and 70 GTO <a target="_blank" href=http://www.geocities.com/modifierperformance>MY vehicles</a>
