lift?
backwoodsblazerk5
Registered Member
houston
I am about to install the 4 inch lifter springs from tuff country and I know Im gonna need longer brake lines but I have seen on some lift kits that it includes a different steering arm. Do I really need a new steering arm and if I do, where can I get one?
I've seen them both ways but the lifted steering arm is much better. Not too expensive and you can get them from just about any place that sells 4x4 stuff & lift kits. I got ahold of a K5 once that the previous owner heated the stock steering arm & just bent it up. Not the way to do it! I replaced it with a new one as soon as I could.
-John
You can get a used one, probably on here for about $50 or a new one for around $100 from cos like skyjacker.
