Cntymnty77
im laying out my plans to pull the body off and I’ve heard of guys doing this but wasn’t sure how big of a pain in the ass it is?
I’ve had different ideas about doing a crane but then started thinking about this idea the other day. I remeber something about someone saying they took the doors off and lifted it from the side so the pick height was lower and allowed them to roll the frame out. That’s reall all I’m needing to do is get it up high enough that I can roll the frame out and then let it rest on some cribbing.I've got it in my head that with one engine hoist, using a 4x4 bolted to the tub body mount locations at the rear, should suffice for picking that end up.
For stability I think you'd want/need something additional up front just in case the balance wasn't perfect, but once the rear was up aways, block it in place, then move up front and using something like a 4x4 under the front of the tub, jack it up and then block it, repeat until needed height.
How high do you need to get it? I'm intending to take the tub and front clip off in one piece, and leaving the drivetrain attached to the frame to roll out underneath, so that will require a lot more height than if you just have a rolling frame to put underneath it.
I've done it in a field, with just a floor jack and some wood...but it shifted, and once that thing starts to go, get out of the way.
Homebrew gantry crane isn't a bad option either.
I guess that I don't see how to lift it from the side and still be able to roll the chassis out without going up and over the engine hoist legs. Maybe go forward some, then use a floor jack under the rear differential to take the back end out and away from the hoist? I wouldn't want to move the hoist with the tub hanging up that high unless it's on nice smooth concrete.I’ve had different ideas about doing a crane but then started thinking about this idea the other day. I remeber something about someone saying they took the doors off and lifted it from the side so the pick height was lower and allowed them to roll the frame out. That’s reall all I’m needing to do is get it up high enough that I can roll the frame out and then let it rest on some cribbing.
