Green Monster
Since I had a bunch on stuff off the motor, I figured I'd change the valve cover gaskets. Well, it seems that I poked a hole in one of them while I was removing the old gasket (seriously, it was like someone welded the gasket on). So first question.....best place to get cheap factory style valve covers? Also, I noticed that on the right side (odd cylinders), the bolts that hold the rockers on are all "uniform", meaning they all have the same thread count sticking out of the nut. Not so on the left side. Some are similar, and a few barely have any threads sticking out. Is this a problem? Engine ran great when I ran it last, about six months ago. Also, pulled the cap off the dizzy. Don't know if it looks good, or bad.....thoughts? Looks like even contact (white marks) on all eight contact points, and can't see any cracks. When I turn the rotor, it snaps back quickly.
And last question, as I haven't got an answer yet on my previous post. First belt (closest to engine) goes on the crank, ps pump and ac. It is barely touching the water pump. I can slide a business-card thick piece of card stock in between and it will stay. I figure this is a problem. Tried various methods of tightening the ac, ps pump, etc. but nothing works. Any chance the new water pump is just cast a little thick? Thought I'd take a grinder to it and give myself about a sixteenth of an inch clearance. Thoughts?
Thanks to the brotherhood for all your help.....can't do it without you!
