Who's running limit straps? I don't hear much about it, but letting the suspension bottom out on the shocks seems like a bad idea. What's the best way to connect them?
I'm not sure I follow, no nothing had to bend around any shocks. It's just a seat belt attached at both ends of the shock. It just catches the weight of the axle just before the shock hyper extends.
Put it on the inboard side of the shock.
Yeah, going to the shock mounts is probably easiest. I wonder if the mounts are up to it, especially in the back of a K5. Also, won't the strap have to bend around the shock? If I'm thinking right, the strap would be pushing sideways on the shock as it tries to get straight.
Honestly inboard or outboard I don't see this as an issue otherwise people would be complaining about damaged shocks. If it's that big of a concern drill holes in the frame and weld tabs on the axle.
^This.
I think you are overthinking this. Maybe with a really soft spring like 56's up front would I think you should really think about this (or possibly 52's). But with the ORD springs, I personally think you would never need them at all and you would notice you went to the work of intalling them to find out you never use them, just my $0.02
I got bored on lunch..red line is strap.. He's saying it will hit the body on extension...
Just gotta move the mounts out. I personally doubt u need them.
I'm not sure I understand what you mean by "use them". If the shocks limit travel, the straps will definitely be used. I think it's just a matter of whether bottoming out the shocks is a big deal.
