"They" (the linelock), work fine but they can cause some collatteral damage to your master cylinder. I had a long talk with the folks at Willwood and the people at CNC Mfg the day before yesterday about ebrakes and linelocks were mentioned. Both are manufacturers of hydraulic master cylinders and both independently mentioned linelocks wear out the piston seals in master cylinders prematurely. What causes the excessive wear is the suddeness of the release of the linelock. Master cylinders are not designed to release presure suddenly, it must be gradual. Yes they go one way hard as when you slam on the brakes but the rubber piston seal tears against the ports when it goes the other way all at once like when a linelock is released.
I was talking to them to help me design a feasible, reasonable cost disc brake/ebrake solution. I think we may have the answer for every application too! And it is not a line lock.....
BTW, I think a cutting brake would work better for a rear wheel lockup under power anyway.
