K5dreamer
Ok, so my truck is smashed up and the body is rusty as hell. there are spots in the front floorboards, and rear bed area that you can see the road through, the passenger side rocker panel is nearly non-existant, the front wheel well liners have big holes in the back side, and the rear wheel wells on the quarter panels have big, nasty bondo spots that are rusting through. oh and the tailgate is indeed cracked on both sides and rusting.
point being... at this point, im questioning the logic of spending money to repair this body, and may look at finding a 73-75, low rust body to swap in its place. So heres my deal. before i mount the body, im most likely going to want to line-x the whole underside, and the inside of the tub. but why stop there? instead of painting my axles when i build em up, figured id line-x those as well, so they are easier to clean off and keep lookin good. hell maybe the trans and tcase as well. of course id hook up coolers for these as ive heard even painting these, let alone line-x coating them, causes more heat build up and possible damage. this would ultimately be the NV4500/NP205/203 setup.
thoughts? cautionary tales? stories about bein nekked? and most important.... anyone know about one of those 73-75 bodies with limited cancer available on the cheap??
