I'm looking for the following parts. I could buy all new, but I'm hoping to find a better deal and keeping it stock would be nice. The list will change as I continue the build.
Truck is a 1978 Suburban body on a 1984 4x4 3/4 ton frame with a 10 bolt front, 14 bolt rear, NP208 and TH400. I'll be building the interior to resemble a 1975-1976, though, as I have doors from those years that are going on the truck.
interior pieces: (preferred color is blue, a must for seatbelts and carpet)
Seatbelts (shoulder belt preferred). I think I've got most of them now except for the middle row belts. I need the male shoulder harnesses that bolt to the C-pillar and floor and then the corresponding female connectors.
Bucket seats, truck came with a bench I could recover, but thought I'd look for buckets anyways FOUND
Center console - FOUND
Dash pad
Walnut dash trim
Front ac vents
Rear ac shroud (the part that mounts to the roof) FOUND
Front door walnut trim panels from a '75-'76. (everything here is ruined on the top most portion because of the sun).
Bolt in third row seat (does one from a Blazer work? ie, are the mounting locations the same?) *EDIT* Or a pop out third row seat from a truck with shoulder belts. I may cut the floor mounts out of another truck.
Carpet (for 4x4 truck)
_________________
Front drive shaft, NP208 to a 10 bolt. The length between the two is ~34"
Transfercase shifter with ball FOUND
Shifter boot and retainer (could I get a measurement of the size/location of the hole in the floor?) FOUND
Skid plates (Transfercase skid FOUND)
Hickey/Confer rear axle truss
3/4 ton hubcaps
_______________________
Hood
Core support - FOUND
