Amtek
I'm at my wits end, no matter what I do the truck stumbles at around 1600 rpm under any throttle position (WOT or just cruising) when under any load. It does not stumble when revving in neutral, but if put it in gear and hold the brakes it will do it.
I've tried it with all vacuum ports plugged (running hydroboost) except for vac. advance, with no change. I've plugged the vacuum advance into ported and manifold with no change. Running at 6 degrees initial timing (for smog purposes), advancing or retarding timing doesnt seem to affect it. Holley 600CFM carb is new 5 years ago, truck sat for 2 years while I rebuilt the 350 which is mostly stock except for very mild summit cam, bored .30 over, edelbrock EGR alum. intake, and higher stall torque converter. No vacuum leaks, no loss of coolant. Stock T-stat temp of 195. New plugs, new wires, cap and rotor. During the rebuild, I took the distributor apart and cleaned and very lightly lubed the weights and put everything exactly the way it was. Vacuum guage needle sits at 15 inHg @ idle and vibrates very very slightly. I've adjusted the accelerator pump with no results.
I have taken a couple of videos to demonstrate the stumble/hesitation
The stumble is very noticeable at 0:27 - 0:34 but the truck is cold.
Here it is again at 6:00 - 6:10 and 6:27 - 6:33
[youtube]a8Z54p1-bOY[/youtube]
any thoughts?
any thoughts?
