INChubbs29
Registered Member
Hello all, I have a 1991 K5 Jimmy, with the 5.7. The issue I am having is I get a great deal of pressure build up in my fuel tank. I have cleared the line from the EVAP to the tank and I can get compressed air at the tank. The valve seems to work just fine in that it opens when vacuum is applied and air will pass through when it is "open", and no air will pass through when it is "closed". I am stumped on this one because at Port A, the vacuum Port on the far right side that goes to the EVAP charcoal canister seems to have no vacuum at all. The line going from the Port to the canister is clean and open, it just doesn't have any vacuum there. The Port A in question seems clean and clear "compressed air will pass through". All of my other ports show strong and healthy vacuum for as many miles are on the engine. Why is there no vacuum at Port A?
