Just wanted to share the good experience after installing the LMC custom headlights and wiring harness upgrade on my '85. I had always been a little bit disappointed in the light output, and adjusting the aim only somewhat improved matters. Changing them was as simple as removing the sealed beam units and plugging everything in. The upgrade harness has two relays, twin grounds, and everything is clearly labled and seems to be good quality The length is also just about perfect . I also like that I can use modern halogen bulbs.
The housings look a lot better than the old lamps, but not out of place on an old truck, and after adjusting the light was whiter, significantly brighter, and shined farther. Overall I'm happy. Not the cheapest modification (around 170 for 4 units and the harness) but definitely safer, and brings better lighting without taxing the old factory harness.
