josh86k10
I finally got around to installing the 1/8" molded industrial polyvinyl (MIP) floor mat from LMC.
The after action report:
After a little trimming, before the seats went in
With the seats installed
Drivers floor board
pedal area
malfunction junction (where the roll bar comes down, and the seat adapter bolts together, and the floor pans "step up")
- The fit is good. Certainly not perfect, but better than I expected. It is a little big in almost every dimension so a decent amount of trimming is required. There are also no holes. I did all of my trimming and hole cutting in place in the vehicle (a little at a time so as to not screw up).
- I didn't measure anything. I just popped the first two holes in the center of their molded spaces. Then I bolted the mat in place, found the other holes, drilled them, and bolted them. With the mat firmly held in place, I then started working my way around the perimeter of the truck. I probably trimmed each place 3-4 times, taking a little each time until I was happy. I only screwed up one place and it took my wife several minutes to find it after I told her what I had done.
- Do this on a summer day. Last winter I could barely unfold this thing, today it was almost floppy and quite malleable.
- Kitchen/poultry shears and a reasonably sharp pocket knife work great for trimming.
- Some have complained that there is little "molding" of the product. I disagree, it isn't perfect but it is obviously intended for this vehicle. That said, mine is a K10 so my floor has lots and lots of contours due to the saddle tanks, unlike a K5.
- I did use the Jute padding and it did tone down the Flowmasters quite a bit. My floor has zero rust and fresh paint so I decided to accept the risk.
- I used a hot glue gun to "spot weld" it down as I went. I didn't want anything permanent and this seemed to work very well. It held things in place nicely so that my trim job was a bit more accurate.
- All in all I am very pleased. The fit and finish is very nice, not exactly factory, but pretty friggin good.
Drivers floor board
pedal area
