LMC or SPECTRA
scoots90245
1/16 ton status
El Segundo
Fuel pressure at 10psi I'm gonna drop the tank and replace sending unit and assembly when engine goes out for rebuild.
Do I buy the Spectra or LMC. I was not able to find OEM/USA /AC Delco or Delphi in stock anywhere
The Spectra looks great in the photo haha was gonna get the ep381 pump to go with it.
The rebuild will be stock
LMC and Spectra come off the same Chines assembly line so it does not matter. I have Spectra sending units in my saddle tank crew cab pick up that work just fine.
i always got for spectra stuff .
and TBI stuff is known for 9-12 psi range all stock . so it might just be normal .
guys add the adjustable reg knob to the tbi unit and check with gauge to get to 12-13 max from what i recall no ecm problems in the tunning .
Good to know thanks
