I just replaced a brake fitting above my rear axle and my brake light came on. I did not bleed the lines yet, but wanted to find the valve too....
Was it wierd that when I removed the fitting from the block above the axle that no brake fluid came out? (im referring to the block where the line off the frame comes in, and splits out to each rear wheel).
