One day I found that I couldnt get my lock cylinder to rotate back into the “lock” position. The key got stuck but with 30 year old parts and generous wiggling it let go. But it would never return to lock again. So I figured it was the lock cylinder and got a new one. I started tearing into today and the new one does the same thing, so I dug down a little deeper and and it looks as if there might be a problem with the rack and actuator.
Now, I’m not certain because I’ve never torn one of these apart, but it does seem that the actuator is being inhibited from rotating any further back than what you can see in this pic. It will rotate to accessory and start fine. I know it’s not the lock cylinder now because once I took the old one out it rotated to lock just fine.
I pretty much got stuck her because I need a pin puller to go any further but does anyone have any suggestions to what’s going on?
and drop the column to get to that actuator rod.
