F-ingrob
Wheres the mud
I've heard people around the local shops say you cant put a locker in the front and others say you can any input from fellow off roaders
I've used lockrights for years, the D60 needed to have the diff removed from the housing to get it in, but my D27 (Jeepster) didn't. Both have performed as expected...no dissappointments
Don't really care if the carrier has to come out I'm changing my gears anyway and wanted to put a lock right locker in the front i have had lock rights before in the rears of 12 bolts in other vehicles and never had issues
Just wanted to make sure that a locker is possible in the front
So you think a true track would be betterYes it is.
Are they talking steering issues. Or breakage issues
OK cool thank you I'll most likely be putting it into two wheel drive but still have the hubs locked when turning anyway I'll be doing it mainly for my ranch there some Hillclimb's and water crossings where I want to stay locked in front. My ranch is 1400 anchers with hills and valleys and rocks.The deal is its hard to steer when your under torque. If you run in 4wd alot on the street a tru trac is definitely better. Won't give as much traction as a locker but will add some.
It's not like you lose steering when in 4wd but your turning radius will increase when in 4wd. Hydro assist helps alot.
Even then I have run 4wd locked front and rear on really bad roads before with no issue. You gotta pay attention though.
Yup most definitely!
I went to put mine in the 60 but the damn roll pin wouldnt come out. Thats ok im regearing too!
you do know it only goes in/out 1 way . . . not a pass threw hole.
