Just4Fun
Registered Member
in this 10 bolt rear end. any suggestions. Kinda NEED the axle shafts outta this thing badly. Thanks
You had luck. Buy your replacement from the stealer, and "polish" it on a bench mount wire wheel. That will tend to clean-up any surface burs on the "cut" threads. Clean both the carrier and the stop bolt with IPA or Lacquer Thinner, let dry, maybe use some Lock-Tight Blue and juuuusssst torque it snug.Tried a magnet right off the bat with no luck. Couldn't get the drill in there sideways to try to back it out so I drilled straight on it for a while right next to the shaft and got it free.
