I have a 83 k5 with power door locks and both doors are locked and will not uunlock, I got in through the rear window but they will not unlock with the switch,key,or knob. Help!!!
If they dont unlock with the key, (froze up) I would suggest you pull the fuse ASAP. My guess is that one of the buttons is stuck down to the lock side of the switch. If you cut the power to them you should be able to use the key.
