Are you looking for the detroit or the carrier to put a detroit into? Just in case you didn't know, the 14ff the detroit goes inside the original carrier.
Like scott said.
I have a 4.10 carrier if you want one.
4.10 and lower or 4.56 and higher are your choices by the way.
If you have an open carrier already then you don't need one, just the detroit lock which is around $400 sometimes cheaper.
