Lokar
skink4president
orlando
FYI - Just installed the whole Lokar cable set-up on my '73 K5 (bracket, throttle cable and kickdown). Everything went very smoothly and the setup looks great. Spent over $100 on all three items :eek1: but everything is stainless, compact and easily adjustable. Prior to this I was dealing with the hassles of a non-adjustable, factory throttle cable matched to an aftermarket carb (edelbrock performer). What a nightmare!
If you want to save a few $$$ the stock kickdown works fine in conjunction with the lokar throttle cable and bracket. That set-up will run you about $60 from Summit or Jegs.
lokar Rocks, theyre just down the street.
The owner of it is a kick ass guy, i've even talked to him about doing matching t-case shifters, he said if i can tell him what i need, he'll do it.
wonder if he'd do triple sticks....
