I'm having second thoughts on welding these up. I already hate the way they look but even if I use 309 filler and tig everything I think they're still gonna crack. The front shackles are wearing through the collectors. I'm not sure if I can heat and hammer them far enough to clear. Then I'd tig v-band on the end to get rid of the 3 bolt flanges that are problematic.
I'd be extremely annoyed if I spend three hours tiggin these pos's and they crack and I have to start over...
Bear in mind, the manifolds are stainless steel cast and the tube is 308 I believe. The heat cycles between the two may very well still be too different and cause a huge crack.
