hmatiak
Any issues having the o2 sensor down in the collector on a set of long tube/full length headers?
yes if you use a stock replacement, no if you use a heated o2 sensor.
With the sensor so far away from the engine it will not get hot enough and the engine will not run at it's peak efficiency.
The standard internet answer is "no. It will not get hot enough."Any issues having the o2 sensor down in the collector on a set of long tube/full length headers?
Beleive it or not it's easier to tune the next bigger cam than the one in the 290HP engine. Why? I have no idea...Last fall I converted my son's '79 to TBI. It has hedman elites on it and I installed the O2 sensor in the collector. During single digit temps at idle it will drop out of closed loop while sitting at a red light and the idle quality would change (290HP GM crate engine). Other than that it made no difference while driving. Some day I'll swap in a heated O2, but it causes no problems as it is.
