uao85
Hey guys looking for some feedback on other peoples ventures in this area as far as driveshaft/pinion angle go, and how you went about correcting it.
I have an 85 cucv m1008 (srw lwb k30), and plan on installing a set of 6" leaf springs up front, and using a combination of shackle flip using spring hangers, with a zero rate. My question is for those with a shackle flip, what was your resulting pinion angle and how did you correct it? Also what would you guys recommend for the rear lift somewhat on a budget? I might even back off to 4 or 5" of lift.
Remington
Remington
