I've run her some but not much. I was going in to change valve cover gaskets and spark plugs. gasket cover bolts were plain loose and then I found these wires, all on passengers side.
I don't lift her hood much but I run her less... and I haven't driven her at all 'cept down the drive a little or to turn her around. The truck has stock manifolds. The driver side has heat shields around the plugs but pass. side doesn't. I'm just getting into the engine to see what I have to deal with.
