Looking at a potential new truck
The water pump is common,is it leaking? We just replaced on on my father inlaws 05 lly. We had to get it done at a shop because we were to busy with feild work at the time,I am glad I`t wasn`t my truck because it`s a big PITA job and I usually work on my own s#it. Cost 700.00 to do the job,yes thats right,the dealer quoted around 1100.00. You could do it your self, there is a great DIY on it at the deiselplace.
I would go and read up on it alittle and then you can decide.
The manual shift tc in that truck is cool though.
And you are right, if the water pump isn`t leaking it could be a simple fix.
The water pump isn't hard you have to have remove the balancer to get it off but overall not a bad job can easily be done in a day for a first timer
