Wanted Looking for a complete hydroboost setup
Atl-atl
Phoenix + Flagstaff
Just like the title says, looking for a complete hydroboost setup for my 78 K5. Planning to swap from my stock vacuum assist when I do my LS/NV4500 swap this winter. Already have the pedals, need everything else. Show me what ya got!
Is this what you're searching for .....
Hard to tell from those pics if everything is there. I want a complete set of parts for a swap as if I were pulling it off a donor truck, see list below.
-Need rod in back of Hyrdroboost unit which connects to brake pedal.
-Need master cylinder (could buy new ).
-Need rod and retainer clip between master cylinder and hydroboost unit.
-Need Hydroboost unit (could buy rebuilt w/ core charge).
-Need mounting plate for Hydroboost unit to firewall.
-Need bracket which holds hoses and fastens to master cylinder mounting bolts.
-Need 2 high pressure lines to Hydroboost unit (could buy new).
-Need 1 metal and rubber return line from Hydroboost unit (rubber is store item, metal part isn’t).
-Need power steering pump with 2 return line inlets. Some have cap on unit, others have remote reservoir which bolts to the alternator bracket.
-Need power steering pump brackets, 1 on front of pump, 1 at back.
-If remote reservoir, will need reservoir, hose to reservoir from pump and bracket (alt. bracket) which reservoir bolts too.
Can't comment about nomenclature....do know I pulled apart a running unit for my conversation...
Best bet would be an unperson inspection.
There are more images in the for sale section
