Looking for a diagram
JT88K5
Central PA
Doing a serpentine belt conversion on my 87. Primarily to restore AC as the old pump doesn’t clear the tall valve covers. I picked up everything bolted to the front of the engine on a 94 Silverado, I should even have all of the bolts. I did not pull the water pump on purpose and will replace it with a new 94 pump.. I asked the junkyard guy to wait until I arrived so I could get a picture and separate the bolts… but he didn’t. :angry1:. He had everything off except the ps pump and that driver side bracket that it bolts to. Plus the old bastard wouldn’t let my brother walk into his yard to help. Should have left then but the price was right.
So… that’s a pretty long intro just to ask if anyone could point me towards an accessory bracket diagram with enough detail to tell which bolts go where?
Found this with a quick Google search - hope it helps.
@tarussell
Thanks but I’m looking for a diagram with detail on mounting the accessory brackets. I found a few similar to the one you posted. I can’t find anything with an exploded view of the accessories/ brackets. I’m sure I can figure it all out, it’s just a puzzle.
Thanks @Wes Harden .. the ps pump installation differs a bit from what I picked up. Looks like I have a bracket that connects to the back side of the ps pump which replaces the rods shown in the picture you posted. May I ask where you sourced those diagrams? It would be great to have the parts list to go along with those diagrams. I read a post on here that referenced a site where you could enter a vin and get this technical info, but I don’t have the vin from the 94 Silverado from which the parts were pilfered. I could probably get it with another trip to the yard if I have to.
I am having difficulty finding that image again. I'll work on it some more.
Find the service manual PDF for 1994 and go system by system. The parts manuals also have good diagrams with part number tables. https://67-72chevytrucks.com/vboard/showthread.php?t=690988
They have good diagrams. This one is from the 1991 service manual for the AC pump.
