Sorry it's late... If there is anything else you want a pic of let me know.
Here's the top of the shroud. The end bolts you see screw in to the radiator mounting brackets (where the rubber bushings are). The inboard bolts go into the cover that spans the top of the radiator (says "caution fan") but it's purely cosmetic, no structural value.
Here's the bottom of the shroud but it's hard to get a good pic of. There are 2 bolts that go into the lip on the bottom of the core support, the same as the shroud on the original 350 set up.
