Keep in mind you'll need both if you're keeping the tie rod in the stock location, the flat top and non-flat top knuckles are tapered from the opposite direction.
I’ve had pretty good luck with the ruff stuff tie rod insert. I’ve got a Reid knuckle that I need to install but in the meantime haven’t noticed any issues with drilling and using the insert.
