Looking for help from anyone in Upland, CA area
Dikaia K5
Newbie
Upland, CA
I bought a project blazer that had been parked for over a year, I rebuilt the engine, everything torqued, etc. to specifications, currently am rebuilding the carburetor to help with starting issues, however, none of the vacuum etc, was hooked up on this when I got it, and I can not find a clear diagram etc showing the different diverters, etc used in the vacuum setup, and want to double check all my wiring if I could too, having a hard time locating the wire which would hook up to the MAP sensor on the firewall..... well, any help would be greatly appreciated, I need to get this going so I can get it sold. Thanks for any and all help!
sorry, was in a hurry earlier, I usually try to be better about that, its a 1985 K5 Blazer, with a 350 in it, I have been having issues with no start after rebuild, I've done a few older without the OBD systems in them, and never had any issues, but this is a whole new ball of wax, so I just want to make sure I get all the vacuum setup right once I get the carb rebuilt, and find the wire that plugs into the MAP, the vacuum is currently hooked up, and the wider plug is in with I believe 3-4 wires on it, and the one that hooks up on the side is the one I don't seem to see anywhere, so I thought if I could see a picture of what it looked like and where it came out of, etc I would have a better time finding it to hook it up, I really don't want to have any issues, I have already redone the interior and everything, and cleaned everything up, so this is the last thing holding me up at the moment. Thanks again for any help
