Simple question (I hope). I'm a bit of a newb at selecting parts for an upgraded motor. I've only ever really replaced things with OEM parts. So, with all the hulabaloo about double rollers being "better" than a standard timing set and the insane amount of variance in cam and lifter choices, I want some opinions or facts from those that have been around the engine block a bit more than myself.
The build is a BBC 489 on a Gen v block. Not looking for killer high performance. This is going in my k5 as a replacement for the wimpy old 305. Heads will mostly likely be small CC edelbrocks with a performer manifold. Should see 8.5/1 to 9/1 compression with the flat pistons and 110CC heads. Not sure on which cam yet but the goal is easy idle with a lower end power band. Again, daily driver, family friendly, camping/hunting vehicle. Not a hot rod. Maybe some light towing but unlikely to ever see max towing capacity.
As for the timing set, I think I want full roller rockers and all that jazz which would mean higher spring rates which could mean I need something better than an OEM timing set. But I also think that hot rodder marketing teams thoroughly convinced me that roller=better. I really don't know if i'd see any noticeably better performance or perhaps more longevity and reliability over a simple hydraulic lifter set and plain old steel rockers.
Money is of course a factor but i'm not against being patient and saving up to buy the right parts the first time. Buy once, cry once.
TL/DR: full roller rocker/lifter setup with double roller timing set or just use a standard hydraulic cam/lifters/rockers and a standard timing set? I want 100,000 miles without things wearing out. Breaking can't always be controlled but I don't want race parts that are only really designed to last 25k.
