Looking for just about everything-
79k20350
3/4 ton status
Ct
So I have 2 builds going. Need alot of parts. No rush on most of it but a couple things are needed asap.
Here's the list, most important objects are starred.
Clean 8' bed within 6 hrs of ct****
Sheetmetal -I'm looking for clean pieces. Small dents/ scratches/minor surface rust is ok, but any rot or severely dented pieces are out.
2 Hoods
2 sets of front fenders
4 front doors
2 rear suburban/ crew cab doors
door panels (if the aren't with the doors)
6' bed
Suspension -
Shackle flip
Shock mounts
Axle-
dana 60 knuckles/ srw hubs (or complete srw if someone has one in the right price range)
Front drive shaft, flange mount - Any condition is ok, length doesnt matter. Im going to have it sized and rebuilt.
Rear fixed yoke driveshaft - Any condition is ok, length doesnt matter. Im going to have it sized and rebuilt.
Crossover steering setup for a d60 (already have a 2wd box)
4 spoke chevy steering wheel
If anyone has any leads,
ford 205
Dana 50 srw hubs
37-8? tires and rims. not set on wheel size, so im pretty open to a nice setup.
Ill keep updating this as I know Ill be coming up with alot more.
I got 60 knuckles .
metrodps posted a link to a guy in pa with new n.o.s. hoods.
I also have a few hoods if your out this way and want used .
How much would you want for the knuckles? If I could find enough things out your way to make it worth the trip I'd probably grab a hood then.
let me dig them out and get back to ya . just to make sure since I moved back in November to new house / shop . I did put all axle parts in 1 spot organized good . so should be easy find . :popcorn::thumb:
Have clean, not perfect, dual tank 87 8' bed $800
Have decent 8' bed, could use RH bedside $475
New aftermarket RH bedside with door $375 with purchase of above
Big bearing ribbed SRW 4.56 V2500 rear with Gov-Loc $375
Dodge Dana 60 knuckles, same as GM except higher steering arms $95/pr
Have Dana 60 SRW hubs
Can deliver all but beds to zip 06359
I bought my 205/ 465 adapter from you a few years ago. Pretty sure I met your dad in North Stonington. Still havent got a chance to use it, but its still in the plans. :thumb:
Can I get some pictures of the beds? I'm very interested in both. I found a solid 8' bed for 500 that needs some dent and minor rust repair. Not really needing any new body panels. So I'd like to compare it. Depending on condition it might just be worth spending the extra $$ to get one in better shape. Are those w/ tailgate or lights?
How much for the hubs and knuckles together?
what's with the **** lol, what a potty mouth
what piece of 208 do you need?
*** just mean i need that **** right away:whistle: I did need a 208 shiifter, but was able to source one localy :thumb:
Also have some OEM style front shafts, double cardan w/round 4 bolt flange to mate to common 4 bolt square on transfer case.
How soon do you need a four spoke wheel?
What color rear door panels do you want?
I am working on a parts suburban with rear barn doors in a blue.
I am in sw Colorado so big stuff is out to ship ya.
