I can do alot of guessing for $180.00! I just wanted to see what needs to be changed when adding the Vortec heads. GM offers a manifold for the Vortec heads using the TBI system so they will work but are they close to the standard heads that if you "added" them to a stock TBI engine the ECM would learn the new airflow requirements?? Surfing the web sites there seems to be alot of people using the Vortec heads and many diffrent stories on what needs to be changed to use them. The truck i'm currently working on has a stock 5.7 with vortec heads and a GM aluminum "carb" manifold with long tube headers. I have added the TBI system with an adaptor plate using a 454 TBI unit. Its not up and running yet but from advice you (dave w) have given me here and on the FSC fourm I have made some changes to my system. I now have a heated o2 sensor and am making changes to the BIN file you put up at moates site for me (ANMW). I was just wondering about changes, if any for the vortec heads on this engine.
I think the GM Vortec / Carb intake with a TBI adapter will be just as good, maybe even better that a Vortec / TBI intake. I've only built one engine using Vortec heads, a SBC 400 about 8 years ago. The Vortec SBC 400 engine owner is using a carburetor. The SBC 400 Vortec engine runs very strong.
I posted the information from Sinister Performance for a couple reasons. They are likely to have more experience with the 7747 ECM than me, and it's likely Sinister Performance has a .bin file for the engine configuration you built? Sinister Performance offers a limited support performance .bin file for $55.00, (something to get started with). I wanted to share .bin options that might or might not have been know to you and other readers.
I think the Vortec heads, and headers will require the fuel tables to be set richer ( slightly larger numbers). Getting the BPW set is the first step, as I mentioned on FSC. The 454 injectors require a change to the BPW. Once the engine is running at idle, check the engine main vacuum with mechanical vacuum gauge. Try changing the BPW up / down to see where the "best" vacuum is. Then it's time to test drive and data record with WinALDL / TurnerPro RT to figure out which fuel tables are rich / lean.
The timing tables are not easy to figure out, so I make my best guess and live with the guess.
If I see knock counts, I retard timing a couple degrees. Vortec heads usually increase compression, so I would keep the max timing to 34 ~ 36 degrees.
Usually base timing is Zero or 4 degrees, so before changing a timing table, I retard / advance the base timing +2/-2 degrees and look for spark knocks.
I think you've done your homework, and it's time to take the final exam.
There is no service manual, or detailed how to book on tuning a PROM. If you have more study questions, please ask. A failure on the final exam can be expensive.
dave w
