HamburgerTime
Registered Member
Good afternoon.
I just bought an 81 k5 blazer in Ecuador and I want to add a kill switch to the ignition (in addition to the one I will be using on the 12v supply to the distributor) and could use a little help with which wire to use. There is a flat bundle of I wires on the bottom of the column and 1 slightly larger pink wire on the top of the column. I wasn't able to find a diagram I was certain was correct because they don't match the amount or color of wires I see on my Blazer but from what i see i think maybe the pink wire is the 12v+ wire i need to splice to install my switch.
I have attached pictures showing the wires so hopefully that will help you help me determine which wire to use.
Thank you for the help.
