So not really wrenching on the K5 for 2 years is starting to show. I was pulling a load of firewood last week and noticed a slight noise on coast. I've had this truck so long that I know what's wrong with it before I even pull over. I knew it was either U-joint or a rear end issue.
Taking it apart, the U-joint is ready to be replaced, but still tight. However, the pinion moves around a little. And I found this metal on the magnet:
(BTW, yes I know it's a gov-lock and yes, I know you hate them. But it has always worked fine for me.)
So I expected a fragged pinion bearing. I tore it apart before ordering parts. The gears look perfect and the only thing I can find that's weird is some chipping of the crush sleeve and corresponding marks on the yoke and outer bearing. So I think the pinion nut just started to loosen. I think I just need a crush sleeve, pinion seal and pinion nut and set it up again. I may replace the outer bearing though while it's open, as it has slight marks on the rollers.
I set these 4.88s up like 5 years ago (brand new) and haven't touched anything since or had any problems.
What do you think? A few new parts, set the pinion preload, double-check the pattern and run it?
