Arrover
Registered Member
I bought this 82 4x4, 1 ton crew cab a couple months ago and I've been tracking down the reason for my sloppy steering. I figured out that my steering box is loose so I removed it from the frame. The truck has a power steering leak. Everything was covered in fluid and I think that was helping the bolts loosen and making the box move on the frame. The frame holes are just a little bit ovalized but not horrible. At one time someone had star washers between the frame and steering box so it must have been doing this for a while. The frame is marred up a little from the star washers and the action of the box sliding on the frame.
My question is: Should I just put it back together with some loctite on the bolts or do you guys think I should install a weld in frame reinforcement kit? I have 33"s on the truck and it's not used for heavy wheeling. It will just be for the street and dirt roads for camping and canoeing. At some point I may step up to 35"s.
