Loosing Power while Offroading
Syrborn
Registered Member
Surprise, Arizona
Hello, I was on my way to Crown king and about a quarter of the way up there and after hitting some bumps it seemed I would loose power. at one point after going up a step hill it died after getting to the top. After deciding to turn around it died and I could not get it started, and we ended up dragging it home. I did notice my battery is not strapped down, could this cause a failure with the pump or possibly blow the Icm from the loose of power from it bouncing? thank you for the help!
Yeah, you might have shook the cable loose or pinched a wire somewhere.
Also had trails knock enough stuff loose in the track to clog the fuel filter
Find something for that battery, even if it's a bungee. I spent 12 hours dragging a Heap of a trail after the battery hit the dizzy.
