Lost Cruise Control after tranny rebuilt
belezeebub
Registered Member
Oregon
I am restoring a 91 ½ Suburban 4x4 Grand Prix Edition I had Cruise control on the way to AAMCO I didn’t test CC on the way back after having the transmission rebuilt, the next day I replaced all the dash lights and noticed I no longer have cruise control (I have a new switch for it but I don’t believe in coincidences anyone have an idea where to start looking if it is something that AAMCO did I’ll take it back but I could have also unhooked a wire inside the dash(I looked I don’t see any wires floating around inside the dash and all the gauges and lights work)
I don't see a fuse for Cruise Control it just will not turn on
Did you check the linkage from the diaphram module on the intake to the Throttle body linkage? Check connections vacuum at the diaphram?
I was going to say the brake pedal switch, since the TCC is also tied into that IIRC. But the throttle side as well, since TV hooks up there.
