Lost Power to CD player
jdbuckshot
Registered Member
Mississippi
i noticed my phone charger didn't have a good connection in the accessory plug so i bumped it and when i did, i lost power there and to my sterio. I check all fuses with a fluke multi meter and were all good. I found the constant power wire on the cd was plugged into one of the 6 BATT location on top of the fuse panel. there was no voltage on any of the 6 batt locations. Is there a fuse or circuit breaker that i can check to find out why i dont have voltage there any more? I have voltage everywhere else in the fuse panel. I did get constant voltage from another source to run my radio, but i would like to get this fixed if possible.
Any help would be great.
JD
I just had this problem too and found the main ground on my battery that connects to the block was corroded pretty bad. I replaced the cable and lug and it works like a charm now.
