Hey guys its been a while since Ive been on this forum, so I figured Id renew my membership and get my old blazer some tlc. anyway its been running great this winter and all of sudden the other night I start it up then moved it about 100' got out and let it idle for a while and it just died. So I pumped the gas and kept cranking and nothing until I smelled gas I just gave up. the next day I went out with inline spark plug tester and sure enough no spark. So I pull the cap and make sure rotors turning and it was, I put the cap back on, crank some more and starter quits,( no power at solenoid) So I trace the puple wire back all the way to firewall and its good. I thought maybe the ignition switch went out, and put a new one in and no results. I Do not know if this has got a neutral safety switch, and if it does I can not find it. Its not on the tranny and their is a switch at bottom of column with a blue and green wire but I think that's a back up light? but I'm not sure. If anybody can give me some insight on this I would appreciate it.
I don't remember if this is in my sig or not, but Its a 1984 K5 350, with a turbo 350 trans, mostly stock and as far as I know the electronic spark control has been disconnected. The Distributor has the three wire going to the cap, as with the hot wire on the bat. side on cap
