Tx Surveyor
Registered Member
Hey Everyone,
I have an '85 K5 with a 305 with a Holley Carb. When I am driving and I get to low/mid range RPM I have a crap load of fan noise coming from the motor, so much that it's deafening if I rev the truck up.
My question is this: If I were to pull my main radiator fan and replace it with 2 electric fans do y'all think I would generate enough airflow to keep the engine cool? Anyone have other suggestions for so much noise? Could it just be the carb sucking massive ammounts?
The carb does need to be replaced says my mechanic, says I need a new vacuum secondary and I had might as well replace with an edelbrock while I'm at it.
Thanks,
Surveyor
Thanks,
Surveyor
