Glad it was an easy fix...
My friend finds a lot of vehicles at his shop with plug wires on the wrong cylinders often,after someone did a "tune up" and brought in the vehicle skipping and backfiring,running worse than before..
I recall my older brother buying a '56 VW Bug decades ago in the 70's ,for 35 bucks,from a guy who said his son "gave up on it" after he was told it needed a valve job...(he joined the army, and told his dad to sell it if it was in his way)...car was in nice shape otherwise too!..
He drove it home,running on 2 cylinders,skipping and back firing all the way,and it barely propelled the car...to start it he had to jump it with a 12V battery and crank it over a good 15 seconds before it would run on its own..(or push it)..despite the 6V battery being good..
My brother tried a complete tune up--plugs,points,condensor,plug wires,and he put in a carb kit,and adjusted all the valves,did a compression test,it had great compression...and it ran exactly the same..
Then he realized he had not checked the firing order,he just put the wires on one at a time,assumed whoever did it last time had the firing order right..--he called a VW dealer and asked what the firing order was,the guy at the service dpartment said "I dont remember off the top of my head--but I think it is stamped on the flange near the generator"..
Sure enough it was, "1-4-3-2" and when he traced the plug wires,he found they had it wired "1-2-3-4" !...after swapping the wires around on the distributor cap,it fired up instantly with no jumping the battery,and it would do a hole shot in first gear and squeak the tires in second...that car ran nice for quite a while too!...(and would be worth several thousand bucks today )..
If your truck was run that way for long,dont be surprised if a muffler decides to start rattling inside,often the backfiring loosens up the baffles in them...it can clog up a catalitic converter too..
