loud sound from front wheel
isaac
so the other day i was going to take the blazer out 4wheeling and i got about 4 blocks from my house and it sounded like my front wheel was making a loud sound. so i turned right around and went home. it didnt sound like grinding but like a bad rubbing sound metal on metal. i havent had time to take my hubs off and inspect but what i am thinking it might be a bad wheel bearing? i recently switched from 8in rims to 10in rims thinking that might be what caused the problem. has anyone had this issue what did it sound like and could it be anything else? any input and suggestions please and thanks.
isaac
look at the rims...
might spray some paint on your caliper and put the wheel on to see if it is rubbing...
Also pack your bearings when you check your hubs... only a couple extra bolts to get to them...
