^^^ Appreciate it man. I dug around and found a fuel pressure gauge I bought for the boat many years ago. I'll check this weekend and see where the pressure sits. If I need to explore the module, I'll give you a call, thanks!
Recommendation, test fuel pump pressure under the truck. Either at the filter, or forward where the flex line is connected to the frame. The lines at the TBI should be bolted to the block, and don't want to "give" much to get a fitting in there.
But it did start and run.
